Is there a way to turn on/off the fillets for structural elements like we could before with Aecosim?
Hello Camaron,
You can turn off and turn on the Fillet by selecting the element and right clicking the element and going to the PS properties.
Click on the PS properties and there you would be able to see General Data under that click on Shape and change Layout to Edges inside and then you will be able to see the beam with out Fillet.
I hope this helps you.
Regards,Alifur
Thanks for the info. Is there a way to turn it off completely?
Yes, from the search ribbon, try to search for Structural Settings and there you will find a tab called Shapes, Select the layout as Edges inside. Then next time on ward whenever you place a beam it will be the Edges Inside.
Thanks I will give this a try.
I have tried this and it doesn't seem to work.
