I want to set up a connection to a WMS server connection from the Belgian government:https://geoservices.vlaamsbrabant.be/AtlasBuurtwegen_wijzigingen/MapServer/WMSServer?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
but I get an error 403 forbidden
other WMS (from the same government) installs very well and is very useful
geoservices.informatievlaanderen.be/.../wms
where can I search for a solution?
is it because the first is a https ?
regards Rik
OBD u8 / OSD 2021r1
Hello Rik,
I do not think having https at the beginning has any issues as the Bentley delivered links have https at the beginning. Looks like a bug. We are trying to reach out to development to get to know the issue behind that.
Regards,Alifur
RikR said:where can I search for a solution?
It is up Bentley development to tell why it does not work. MicroStation WMS capabilities (as well as WMTS and WFS) are notoriously bad and buggy, never returning any meaningful information what communication with server was done and what is wrong.
I tried the same URL using QGIS and, as usually, I do not see any issue with published data. QGIS accepts URL and allows to display both data layers.
RikR said:is it because the first is a https ?
As Alifur wrote, it is not a big difference. In fact, even when primary address is https, data source is defined at http (can be seen e.g. in GetCapabilities result).
Jan
Hi, thanks for the clarification,
up to Bentley to take action
Hi,I have the similar problem with CE U16.2:with this link https://cartoweb.wms.ngi.be/service?request=GetCapabilities&service=WMS&version=1.3.0
This link works but you can't see the image (camera view) https://www.mercator.vlaanderen.be/raadpleegdienstenmercatorpubliek/ows?SERVICE=WMS&service=WMS&request=GetCapabilities
In advance thank you for your helpThomas
Hello Hubert,
It would be best if you can raise an SR so that a corresponding bug can be filled for the link so that development team can have a look into the issue.
