File naming-path from Projectwise
Hello there
AECOSim Connect Update 4
PW Version 10.00.03.334
Possibly this is a PW question but for now ....
Please see the image below
For some reason, in the Reference Manager, the file names are always proceeded by some PW reference (in the red rectangle). Presumably related to where the file is actually is in the 'Local' copies of the PW folders on my C drive
Is there someway of getting rid of this? It is irrelevant to the users and just makes the file names excessively long. I'm constantly having to enlarge the Reference Manager so I can see what's what
Would be handy to get rid of this?
  • Hi Danny,
    With ProjectWise the filename is preceded by the local folder name and the PW_WORKDIR to make it clear that the local cache is being used.
    Display of the path does appear to behave differently in this context.
    We can check to see if an enhancement has already been filed requesting a change to this.
    Marc
  • Yes, it would be good to get rid of this.
    Can only suggest that it always uses the local copy by default (which generally it should be doing ..........)
    Can only guess that in come cases, for security purposes, it never uses local copies and everything is downloaded directly from the server ....
    But, for standard use, ..... we could do without this unnecessarily long file naming. Maybe then if for some reason it isn't using the local copy, it shows up in a different colour, or has an 'symbol' next to it
    Danny Cooley
    Freelance AEC CAD/BIM Technician Architecture, MEP & Structural  ..... (& ex Low Carbon Consultant, ..... because they weren't that bothered!)
    OBD Update 10, Windows 10 Pro, HP Z4-G4, 64Gb, Xeon 3.6GHz, Quadro M4000
Reply
    Danny Cooley
