Is OpenBuildings Designer capable of doing domestic pipework sizing calculations based on British Loading Units (like Hevacomp NetSys)?
Thank you!
Hi Adam, OpenBuildings Designer has the option for the Pipe System Sizing utility for the systematic way of computing and sizing the pipe through the interface-based mechanism.and has three Primary Standard for the pipe design data i.e. CIBSE (UK Standard), ASHRAE (US Standard), AIRAH (AU Standard). Please see the attached image for your reference.
HTH
Shivam Soni
Hi Adam,
While there is indeed functionality in OpenBuildings in this regard currently, it is planned that it will fully incorporate the functionality of Netsys with the release of Update 10. The information in the below announcement should hopefully assist in clarifying:
Hevacomp to OpenBuildings - Transition update - Energy Simulation Forum - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Steve Cocchi
