[OBD SDK Connect Update 8] - modifying Structural Elements with Open Building SDK (STFC-Api)
I need to change some Properties of a Steel Beam Element in Open Building Designer Update 8 using the C-Api "stfc-api"..
Until now I've been able to read the "LinearMember" out of the EditElementHandle and to change some Properties in it using
following Code:
virtual StatusInt _OnElementModify(EditElementHandleR eehSteelBeam) override
		StatusInt statusInt;
		MSElementDescrP elmDescrP = eehSteelBeam .GetElementDescrP();
		STFLinearMemberList* linearMemberListP=mdlSTFLinearMemberList_constructFromDescr(elmDescrP , false);	//SUCCESS
		if (!linearMemberListP)return ERROR;
		STFLinearMember* linearMemberP=mdlSTFLinearMemberList_getLinearMember		(			linearMemberListP		);	//SUCCESS
		if (!linearMemberP)return ERROR;
		DPoint3d pP = { 0,0,0 };
		DPoint3d pQ = { 0,0,0 };
		mdlSTFLinearMember_getPQPoints(linearMemberP,&pP, &pQ);	//SUCCESS
		pQ.z += 2000000;
		statusInt=      mdlSTFLinearMember_setPQPoints(linearMemberP, &pP, &pQ);	//SUCCESS
		statusInt=mdlSTFLinearMember_save(linearMemberP, false);			//ERROR: 32768
		//statusInt = mdlSTFLinearMember_replaceInDgn(linearMemberP);		////ERROR: 32768
		mdlSTFLinearMemberList_free(&linearMemberListP);
		return SUCCESS;
But when I try to save it to the DGN It allways brings The ErrorSatus (StatusInt) = 32768 and nothing happens.
I tried "mdlSTFLinearMember_replaceInDgn" , "mdlSTFLinearMember_save" and "mdlSTFLinearMember_addToDgnExt" but nothing is working.
Hopefully there is sombody out there with some experience with the Open Building SDK.
Many thanks in advance for your efforts
Greetings
Manuel Höger
Softwareentwicklung | mhoeger@cadcom.de
Tel: +49 30 - 53 63 62 – 44 | Mobil: +49 162 - 53 18 640
cadcom® Systemhaus GmbH
Stralauer Platz 33 | Kontorhaus |10243 Berlin
Tel: +49 30 - 53 63 62 – 0 | Fax: +49 30 - 53 63 62 - 30
www.cadcom.de
  • Sorry my fault, Was too late yesterday... I missed to change this function. Now it works perfectly.
    Wonderful! Thanks.
    Maybe you have some more additional Function hints about placing Architectural (TriForma) Elements like a ladder or other parametric cell Elements (I try to place a Parametric (CEL) cell.? This would be so nice!
    [OBD SDK C++ Update 9] Placing Triforma Element with "Loadables" - OpenBuildings | AECOsim | Speedikon | Forum - OpenBuildings | AECOsim | Speedikon - Bentley Communities
  • Wonderful, I will take a look at placing parametric cells with API
  • Not the normal parametric Cells, but the user defined Catalog Element Cells. Defined as "Paradef:Cel(Parametric)" in Calalog Manager. Just for clarity!
    Tanks again and in advance!
  • Hi Mykolas,
    Is it possible that you send me the rest of the mdlstfstructuralmember_ header signatures? I want to create a structural member as well and at the moment I'm doing this with a dotnet workaround. This is not very satisfying.
    Greetings
    Manu
  • Here it is
    TFAPI_EXPOSE void mdlSTFStructuralMemberClass_freeMem
    void* pMem
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_constructFromCurveDescr
    STFStructuralMemberList* pThis,
    MSElementDescr*          pDescr,
    DgnModelRefP             pModelRef
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_initialize
    STFStructuralMember* pThis
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_initFromElementDescr
    STFStructuralMember* pThis,
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_copeWithDefaults
    STFStructuralMember* pThat,
    bool                 cutAtStart
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_constructFromElementDescr
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setRotation
    double               rotation
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setRotationDegrees
    double               rotation
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getRotation
    STFStructuralMember const* pThis,
    double*                    pRotation
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getRotationDegrees
    double*                    pRotation
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setPlacementPoint
    int                  placementPoint
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getPlacementPoint
    int*                       pPlacementPoint
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getInsertOffset
    double*                    pOffsetX,
    double*                    pOffsetY
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setInsertOffset
    double               offsetX,
    double               offsetY
    TFAPI_EXPOSE bool mdlSTFStructuralMember_isMirrored
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setMirror
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_resetMirror
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setSlope
    double               slope
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setPQPoints
    DPoint3d*            pP,
    DPoint3d*            pQ
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getPQPoints
    DPoint3d*            pP,
    DPoint3d*            pQ
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setFullCrossSection
    WChar const*         fullSectionName
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setCrossSection
    int                  shapeType,
    WChar const*         shapeClass,
    WChar const*         sectionName
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setPSSection
    STFPSSection const*  pSection
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getCrossSection
    STFPSSectionList**         pSectionList
    TFAPI_EXPOSE bool mdlSTFStructuralMember_hasFireproofing
    TFAPI_EXPOSE MSElementDescr* mdlSTFStructuralMember_getFireproofingElement
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setCatalogItem
    TFCatalogItemList*   pCatalogItem
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setCatalogItem2
    WChar const*         pDataGroupType,
    WChar const*         pDataGroupItem,
    bool                 updatePartFamilyValues
    TFAPI_EXPOSE TFCatalogItemList* mdlSTFStructuralMember_getCatalogItem
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_initNamedProperties
    TFWStringList const* pType,
    TFWStringList const* pName
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getNamedPropertyValue
    TFWStringList const*       pPropName,
    bool                       bDuplicate,
    TFWStringList**            ppPropValue
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setNamedPropertyValue
    TFWStringList const* pPropValue
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setPartNameAndFamily
    TFWStringList const* pPartName,
    TFWStringList const* pPartFamily
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setPartFamily
    TFAPI_EXPOSE TFWStringList* mdlSTFStructuralMember_getPartFamily
    TFAPI_EXPOSE TFWStringList* mdlSTFStructuralMember_getPartName
    TFAPI_EXPOSE TFWStringList* mdlSTFStructuralMember_getMaterialName
    TFAPI_EXPOSE TFWStringList* mdlSTFStructuralMember_getMaterialGrade
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_initStructuralDataFromPart
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setTypeString
    WChar const*         pTypeString
    int                  stringNumber,
    WChar const*         str
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setMark
    WChar const*         pMark
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setMaterial
    WChar const*         pName,
    WChar const*         pGrade
    TFAPI_EXPOSE MSElementDescr* mdlSTFStructuralMember_createElementWritten
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_swap
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_duplicate
    STFStructuralMemberList** ppCopy
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMember_getGeometryAtFraction
    double               start,
    double               end
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_replaceInModel
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_updateWithObdDataInModel
    TFAPI_EXPOSE bool mdlSTFStructuralMember_hasStructuralDataAttached
    TFAPI_EXPOSE TFFormRecipeList* mdlSTFStructuralMember_getTFFormRecipeList
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_getNext
    TFAPI_EXPOSE void mdlSTFStructuralMemberList_free
    STFStructuralMemberList** ppThis
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_setNext
    STFStructuralMemberList* pNext
    void
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_construct2
    STFStructuralMemberList** ppThis,
    STFStructuralMember*      pStructuralMember
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_getLast
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_append
    STFStructuralMemberList*  pAppendList
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_addMember
    TFAPI_EXPOSE STFStructuralMember* mdlSTFStructuralMemberList_getStructuralMember
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_duplicate
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_prepend
    STFStructuralMemberList*  pAdd
    TFAPI_EXPOSE void mdlSTFStructuralMemberList_insertList
    STFStructuralMemberList* pInsert
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_unlinkNode
    STFStructuralMemberList*  pRemove
    TFAPI_EXPOSE int mdlSTFStructuralMemberList_getIndex
    STFStructuralMemberList const* pThis,
    STFStructuralMemberList const* pSearch
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMemberList_reverse
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_getNode
    int                      index
    TFAPI_EXPOSE int mdlSTFStructuralMemberList_getCount
    TFAPI_EXPOSE STFStructuralMemberList* mdlSTFStructuralMemberList_constructFromFilePos
    ULong        filePos,
    TFAPI_EXPOSE DgnModelRefP mdlSTFStructuralMember_getModelRef
    TFAPI_EXPOSE TFIdList* mdlSTFStructuralMember_getFireProofingIdList
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setFireProofingIdList
    TFIdList*            pIdList
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_reWriteFireProofingIdListToFile
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_replaceInDgn
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setStructuralPropertyByName
    WChar const*         name,
    WChar const*         value
    bool                 cutAtStart,
    int                  layout,
    int                  edgeLayout,
    double               flangeClearance,
    double               webClearance,
    double               radiusCorner
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_copeRich
    bool                 cutAtStart,
    int                  layout,
    int                  edgeLayout,
    double               topOutside,
    double               topEdge,
    double               topInside,
    double               downOutside,
    double               downEdge,
    double               downInside,
    double               web,
    double               radius
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_delete
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_setSymbology
    TFSymbology*         pSymbology
    TFAPI_EXPOSE StatusInt mdlSTFStructuralMember_getOrientationVectors
    DVec3d*                    pXVec,
    DVec3d*                    pYVec,
    DVec3d*                    pZVec,
