Hello All,
I need to change the size, position and rotation of an OpenStructures Element in OpenBuilding Designer. Ma first attempt, described in the post: [OBD SDK Connect Update 8] - modifying Structural Elements with Open Building SDK (STFC-Api) - OpenBuildings | AECOsim | Speedikon | Forum - OpenBuildings | AECOsim | Speedikon - Bentley Communities was queued as a Bug and is therefor not applicable yet.
Does anybody has an Idea how to approach this problem in a different way? Or does anybody has a clue for a workaround.
I'm thankful for every hint.
Greetings
Manuel Höger
Hello Manuel,
The bug has been reported for the developers to have a look into the forum post. Once the bug will be looked by the developer then he will suggest an workflow for the same. I would attach this forum thread to the same bug so that the dev can have a look into this too.
Regards,Alifur
Regards, Alifur
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
You can download the ProStructures.Net CHM file here:https://communities.bentley.com/products/prostructures/w/structural_drafting_and_detailing_-_wiki_de/58319/prostructures-net-hilfe-chm-datei
