Does the Place Stair tool among all the various constraints possible allow for user definition of the gap between two flights of stairs when creating a "half-turn" stair? so far as I can see the minimum separation of the flights is 250mm between closed stringers.
Let me look into this, I know we have a way to control the minimum distance between the two stair runs in a Half Turn configuration, but it may not be exposed or link making this unfortunate casual relationship. FYI - I'm sure you have discovered you can edit this distance after placement or using the HUD when you select the stair assembly.
Jeff Ashley
Thanks Jeff,
I may have created this particular stair incorrectly then, as I cannot find anyway to edit after placement; although some handles do appear for editing the stair, no dim HUDs show up; not even on the default stair defs. Is this likely to be a dataset error?
Do you have Dimensions turned on in View Attributes?
Yes,
Not every element within this model displays dimensions in the HUD when selected which is why I thought that perhaps there might be an error in the element creation?
