I am currently working through some Bentley OpenBuildings Designer learning paths. But sometimes I am coming across training videos that doesnt tell you where to find the training files or models from.
Is there a central location where these are all usually available?
Hi Steven, For OpenBuildings Designer, the training datasets are usually installed with the product with either the Dataset_US or the Dataset_NM. If that is not the case. you should find a 'download' icon in the course which will include the workbook and dataset.
If you are viewing the course on YouTube you will need to go to the Bentley Learn server to find the dataset download. Is there a particular course you are trying to find? Perhaps I can help you find the dataset.
Mary Chib
Thanks for the reply Mary.
For example the video I'm currently watching shows a location of the file in the video
But I've checked on my machine and that model isn't there.
Also the learning path that I'm on doesn't seem to have that download button like in your snip.
The overall name of the learning path i'm on is called:
OpenBuildings Station Designer: Welcome to Station Designer for New Users Learning Path
Steven, Go back to the Learning Path for this course and you will find a separate course on downloading the dataset for the entire Learning Path.
Hope that helps,
Mary
Answer Verified By: Steven Smithwhite
Great, thanks for explaining Mary.
Steven
