Working this morning using U8 saw the notification that U9 was available so thought I would download and install
It takes forever to install
Eventually able to start working again and find I can't because it won't let me I am confronted with this screen and there is no way past this
I don't use worksets I have no need of them
How do I proceed from here to actually earn my living when the software doesn't allow me to work as I did a couple of hours ago?
Ian
I made the mistake of Installing this update thru the Connection client and I see the same result.
Although I redirect my workspace and Worksets, I still use the installed Dataset_US data. From what I can tell, it made a backup of the Dataset_US folder and created a new Dataset_US folder. But this new folder only has 3 folders with a few files in it. So now OBD cannot find the dataset.cfg that no longer exist and nothing works.
Gary Manuel
OBD Update 10.10.00.197
Windows 10 Pro
Hi Ian,
It seems installation is not successful, I can see workspace is missing. OBD does not work without Workspace and Workset.
Is it possible to share the installation log if possible to review ?
Thanks and Regards,
Sandeep
Where would this install log be located
currently using OBD 10.09.01.38
Yes the configuration folder shows that all the back_up datasets created from U7 - U8 have now been backed up again
without any notification that this was going to be done
Hi Ian,You will get the log in your C drive, under this location, C:\Users\User.Name\AppData\Local\Temp
