In OBD, versions ago, we use to have more doors and windows available.
Even with the fresh install of Update 9, while using the US dataset and the BuildingTemplate_US, I only see HM doors and AL windows and the list is limited.
Why do I no longer see the option to place WD windows, overhead doors or doors with sidelights?
I have been able to find and incorporate some of these from past version as PAZ xml files. When I do, I get duplicates of the ones that are available in the PAZ file and the ones already in the dataset.
Am I missing something?
Hello Gary,
Could you please file a service request on this ? We need to look after this in a live session.
Thanks & Regards, Arindam
Hi Gary,
Did you tried to load additional doors and windows using the Catalog Item Manager?
Select the available door libraries you need:
Select catalog items to load
And you must have access to all the new items:
Hope this helps you.
Eduardo
Answer Verified By: Steve Cocchi
Thanks Eduardo. You are right, I can and have added them this way.
I guess the question I should have asked is why do these have to be added. They should be part of the delivered.
Gary Manuel
OBD Update 10.10.00.197
Windows 10 Pro
