Hi Updated to version 9 and could not get Compound Slab to work. We have a company dataset that I updated with CompoundSlab.xml then single slabs worked but not compound slabs. Does anyone know what more files need to be updated.Pelle
Hi Pelle,
Can you please check whether you have the definition file for the compound slab or not i.e. CompoundSlab_Application.xsd under this location (C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\DataGroupSystem\)And also let us know if it's only happening in your custom dataset or also with the delivered dataset and can you share the images when you place the compound slab?Regards,Shivam Soni
Hi Shivam
The .xds file is in the right place. Tried with the Swedish dataset and then compounds slabs work very well.
Pelle
Hello Pelle.
By looking at the Compound slab catalog looks like there is part & family for Layer 3,4,5,6 is not defined. As the layers are not correctly configured the slab is not getting placed.
Try to go to the compound slab settings from the compound slab placement dialog and set the layers properly.If we look at the delivered compound slab, all the layers need to have proper part & family or material so that it can get constructed. So i would request you to check the compound slab settings to resolve the issue. I hope this helps you. Regards,Alifur
Answer Verified By: Pelle Öhlin
Thanks for the reply. Now it works
