I'm using a 'Mechanical rule' to display some information about the piping on a drawing in OBD Update 9. It works very well to display: Diameter, Slope and the pipe level at start and end.
Now I have a question about the formatting of these labels:
For example the snapshot above has the diameter set to "Above" 100x text height and slope to "Below" 100x text height. Still they appear on the exact same spot.
This is an example of the settings of one of the attributes:
I presume the "Format" box which now displays '%VALUE%' is where I can setup how the bottom-of-pipe level is displayed? Please refer me to the wiki page / manual / ... where I can find more info about this.
Then a third question: It looks like when I change "Justification" for one of the attributes it changes for all of them. I'd like to align the "End" level with a 'Right middle' position so that it's always displayed within the pipe segment.
Thank you in advance for any help!
Hello Johan,
I am searching for the associative wikis regarding your queries, meanwhile you can file SRs individually on these queries. We would like to have a session with you to discuss about all of these features.
Thanks Arindam Roy
