Hi
I have Openbuildings designer on a high res laptop monitor- the pointer is very very small- I can't seem to increase this - any suggestions?
Hello David,
I hope you have tried with the mouse pointer settings. Could you please let us know about your screen resolution ?
Thanks & Regards, Arindam
The following article has some general tips for working with high resolution monitors:
https://communities.bentley.com/products/microstation/w/microstation__wiki/31077/user-interface-tips-for-high-resolution-monitors
