i want work with 2 more , but file same ..( like Revit SYNC) how do work 2 people in same file at once..
Hello Farrukh,
I am presuming that you are asking about how to work on a single file simultaneously within multiple application. If this is your query then I would like to ask in which applications you are planning to work on. You have mentioned Revit , SYNC above, but would like to confirm that part.
Thanks, Arindam
We do not have multiple user access to DGN files. Multiple users are accommodated by federated project structures where a project is broken down into DGN and other files containing appropriate portions of the project. The granularity of that breakdown will depend on the scale/complexity of the project and the team working on it.
Marc
As Marc pointed out this is not possible an example of what he describes is to have a working file for each user referenced into a master file and then reference that master into the individual users file that way an edit in one file can be seen by each user, though they will not be able to edit the elements from the other user.
