If I have Drawn a cylinder with it's geo referenced points ie Start X: 200 Y:300 Z:10 End X:23 Y:278 Z:90 this can be viewed and modified in it's properties. In the future I might need to modify the End as an example to say X:24 Y:278 Z:987 or I might have actually moved the End points to this location and it now gives me these values.
My question without copy paste is how to show these coordinates in a schedule, which should automatically update whether I move geometry or update via the properties.
OpenBuilding Designer CONNECT Edition Update 8
Version 10.08.0044
Hi William,
If you're using a Schedule that means you're working with DataGroup properties, something a plain cylinder (solid) would not have. Were planning to add DataGroup instance data to the cylinder or is it being place from a DataGroup enabled tool?
