OpenBuildings Designer Connect silent install
I created a /layout file for OpenBuildings Designer 10.09.00.83, and checked on the option to create a desktop shortcut. But when running the install that is generated by the layout, no desktop shortcut is created.
I opened the .lyt file and see that the value in the Desktop Shortcut configuration item is blank. But changing the value to yes does not help either.
<Property Id="InstallDesktopShortcut" Value="" Type="String" />
What do we have to do to get this feature to work?
It seems like the same issue we had with OpenRoads silent install
Parents Reply Children
