From an excavation *dgn model, I obtained negative values for some of the Volumes, Please see the image above.
Please can you help us with this issue? we don't know the reason for those negatives values or '0'
Karina
Hi Karina,
Assuming this is an Excel sheet, which tool did you use to export the data from OpenBuildings? And using which version of OBD?
Also, you referred to the dgn model as excavation data - were the elements modeled using tools within OBD or brought in from other software?
Hi Steve,
Thanks for your prompt reply.
All elements of this excavation model were drawn in AECOsim Update 4 using tools within AECOsim.
The data was extracted from AECOsim selecting 'Export' and 'Excel' format.
I hope this information will help us find the reason for these 'Negative' and '0' values.
Please let me know if you need any additional information.
Hello Karina,
Any change you used a 'mirror' command on those elements that are showing a negative value? If yes, I had the exact same issue about half a year ago in OBD U8. I filed an SR 7001325083, which resulted in an enhancement. Can't find any reference number for that enhancement.
