Hi All Is there a "WorkSet Creation UI" so u can redirect Workset to a network projects folder?
Any help is very appreciated.
James
Hello James,
Thanks for raising this. You just need to root your workset folder to the location where you wish to save your project, be it your local folders or a network drive. And in further, you would have to edit the configuration setup as described here and you would be fine!
Krishnendu
Hi James,
Personally I would always create new WorkSets manually from a template to ensure complete consistency. There is a create WorkSet wizard but I'm not happy with it's behaviour when projects are located (as they should be) in a separate network location from the configuration. There is some guidance in this blog: CONNECT Edition - Custom Configuration - Part 5 : Separating Project Data from Standards
Marc
