How can Flyover preferences be added to the workspace level? Can they be added to a dgnlib?
Hello Mark,
As per the current scenario, we can not assigned that into Workspace level. For Default settings it is available in Dataset level. After any customization a new xml file gets created to Workset level. This xml file gets generated within workset>standards>setting folder.Thanks & regards, Arindam Roy
What variable dictates where this xml gets placed? I cannot find an xml that is created.
Interesting!
I saw File and Ref. But what about Model?
regards /Thomas Voghera
Hi Mark,
This is currently hardcoded to generate a new XML file in <PathToWorkSet>\Standards\Setting. There isn't a variable, you would need to request an enhancement for this via a Service Request.
Marc
I see where the file is created. Is it supposed to be removed when the flyover preference dialog is closed? When I make a change the file is created then when the dialog is closed the xml disappears.
