How to get Multi-Category Schedules to show all Catalog Types on the same table?
When I create a Multi-Category Schedule, and select it, it displays the column headers, but instead of displaying items, it says "There are no items to display".
To see the items in the table, I have to drill down into the specific Catalog Type that contains the item.
But what I want is to have all model elements in the same table, regardless of the Catalog Type.
Screenshot below: the model contains a Pipe, a Wall and a Beam.
If it helps, this is something that I know used to work in the past, but ever since I switched to Update 8 it no longer does. In my previous project we started using ABD Update 1 or 2, and it worked out of the box, but then we switched to ABD Update 4 and it stopped working, but I believe we managed to trick it into behaving like it used to by using the old XML Layout files from the previous workspace.
