When I create a Multi-Category Schedule, and select it, it displays the column headers, but instead of displaying items, it says "There are no items to display".
To see the items in the table, I have to drill down into the specific Catalog Type that contains the item.
But what I want is to have all model elements in the same table, regardless of the Catalog Type.
Screenshot below: the model contains a Pipe, a Wall and a Beam.
If it helps, this is something that I know used to work in the past, but ever since I switched to Update 8 it no longer does. In my previous project we started using ABD Update 1 or 2, and it worked out of the box, but then we switched to ABD Update 4 and it stopped working, but I believe we managed to trick it into behaving like it used to by using the old XML Layout files from the previous workspace.
Thanks Aifur, will do.
Accidentally, I discovered that if I keep the "Curtain Wall | Panels" and "Curtain Wall | Frames" out of the schedule, it works. But as soon as those types are in the schedule, it won't. I will add that to the SR.
Hello Enrique,
Yes i did have found the same. Those are part of Curtain Wall System.
Regards,Alifur
Alifur, apologies if this is a stupid question, but do you know if my Admin has to do anything for me to be able to raise OBD service requests? When I go to the SR manager on the Connect centre, I am only given the possibility to raise SRs for ProjectWise products.
I have raised an SR on behalf of you. Not sure about the settings.
