How do I export to dwg so only used levels appear in the dwg?
Hi Thomas,
does compressing the file before exporting help.
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Hi Brenden
No, same levels still in the dwg.
regards /Thomas Voghera
I suppose I can start ABD/OBD with another configuration without dgnlibs and do the export. But I really want to avoid that,
Is there a command that temporarily disconects/hides the levels from a dgnlib. Or better, exclude them from the export.
I thought this was a standard requirement for dwg delivery.
How do you all send off your dwgs? With all levels still in the file, or delete manually in the dwg?
bump
