I am creating some Custom Catalogue Items and adding custom definitions to the catalogue items. The steps I followed are as below.
1. Create New Definition File in Definition Editor.
2. Create Custom Properties under the new Definition File.
3. Create a New Discipline Group in Catalogue Editor.
4. Create a New Catalogue Type in New Discipline Group and applied custom properties which I created in Step 2.
5. Create a New Catalogue Item.
6. Apply Catalogue Item to 3D Smart Solids.
The question I have is related to Custom Properties, the reason I have created custom properties is to fill in the information as required and it will appear as part of BIM information. Everything is working as planned apart from one custom property (Length, as shown below image). OpenBuilding is automatically filling this information and I can't edit it. This is in one manner good, but I want to understand why OpenBuilding is filling this automatically and what other information I can set up this way that it will read element property and fill in automatically.
Hi Jaimin,In Catalog Editor can you please see if any 'Parametric Name' is chosen for 'Length'?
Regards,Shreya
Hi Shreya,
I have checked the Catalog Editor, Parametric Name are empty,
Hi Jaimin,In the Definition Editor, can you please see if any Default value is given for this property named 'Length'? And also can you please tell us which version of OpenBuilding Designer you are currently using?Regards,Shreya
Hi Jaimin,
Length is a standard DataGroup structural quantities schema property (StructuralQuantities). This property is derived by calculation based on geometry. Can you please try rename the 'Length' property to something else ?
HTH,
Sandeep
Answer Verified By: Jaimin Patel
Hi Sandeep,
Thanks for your answer, I had the same impression that it is coming from one of the standard definitions. It opens a new door for me. Can you tell me a list of properties that I can populate automatically same as Length?
Jaimin Patel.
