Hi all, over the past few years I have created various cell libraries mainly in Aecosim V8i. I'm now using Openbuildings Designer and while I can use all my libraries I created previously I can't add any new cells to them.
Is there something I missing or can this not be done?
Hello Stephen,
When you are trying to save new cells inside the v8i cells, is there any error message that is popping up? If its possible then can you send us the cell files so that we can try to save cells in there.
Regards,Alifur
I am wondering to hear this. This should work fine in OpenBuildings Designer too. Could you please share your cell files here ? Thanks & Regards, Arindam Roy
