I'm not able to place any slab. Maybe there is a bug..
Windows 11
OpenBuildings Designer Connect Edition Update 9
Version 10.09.00.83
BuildingTemplate_DE
best regards
Hello Ole,
Can you please have a look at this location and see whether there is any compoundslab.xml is present or not."C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_DE\DataGroupCatalogs\CompoundSlab.xml".
Regards,Alifur
the file CompoundSlab.xml is not listed in this folder.
Ole
Hi Ole,
We have a wiki link regarding your concern in our community. Please follow the steps as outlined in this wiki.
HTH!
Regards,Sayan Acharyya
I don't have the folder C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_NM
And in C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_DE\DataGroupCatalogs
the file CompoundSlab.xml is not included.
Where do i get the file "CompoundSlab.xml"?
Please download the xml file attached below. Then paste that in the datagroup catalogs dialog. Hope this helps you solve the issue.
<?xml version="1.0" encoding="utf-8"?> <DataGroupSystem> <Version major="1" minor="0"/> <Units master="m" sub="cm"/> <CatalogItems> <CatalogItem type="CompoundSlab" name="NZT35-25-20"> <Defaults> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@ActiveLayer" value="0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1PartDef" value="Bodenbeläge, Wandbekleidungen::Trittschalldämmung EPS" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1Thickness" value="0.020" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsCore" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2PartDef" value="Bodenbeläge, Wandbekleidungen::Zementestrich" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2Thickness" value="0.025" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3PartDef" value="Bodenbeläge, Wandbekleidungen::Nutzschicht" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3Thickness" value="0.035" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgePartDef" isHidden="true"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlab" name="NZTW35-65-32-70"> <Defaults> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@ActiveLayer" value="0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1PartDef" value="Bodenbeläge, Wandbekleidungen::Wärmedämmung EPS" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1Thickness" value="0.070" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2PartDef" value="Bodenbeläge, Wandbekleidungen::Trittschalldämmung EPS" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2Thickness" value="0.032" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsCore" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3PartDef" value="Bodenbeläge, Wandbekleidungen::Zementestrich" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3Thickness" value="0.065" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4PartDef" value="Bodenbeläge, Wandbekleidungen::Nutzschicht" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4Thickness" value="0.035" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8Thickness" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgeSetback" value="0.000" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgePartDef" isHidden="true"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> </CatalogItems> </DataGroupSystem>
