Just realise I can't find where to select the active family and part in the default ribbon interface. Is the family/part toolbox the only available option?
Best regards,
Tuan le
Hi Tuan,
Thanks for raising your issue with us.
Can you please elaborate a bit more so that we can further investigate and share some images with us, Is it when you place any element in the model you want to put those elements in your required active family and part?
Shivam Soni
That's correct Shivam. For something as integral as Family/Part in OBD, I'd have thought the toolbox would have an equivalent ribbon wise.
Thank you very much for being with us.
It seems like an Enhancement as the only way this can be done is by removing the part definition name from the respective element Parts XML file.
Can you please raise Service request so that I can create an Enhancement to your SR number?
Creating a new Service Request (Technical Support) Access Service Request Manager as described here . Below describes how to log a new technical, product-related Service Request using Technical Support tile; other categories/forms follow the same design… Last edited 10 months ago in Licensing, Cloud and Web Services > Licensing, Cloud and Web Services Wiki
