I want stop command in right click .i was install new software after updating window , my right click command is not working, how i enable right click cancel command,.
Hi Furrukh,Please try to delete the marked folder which you will find in the location shown in this image below. Then restart the AECOSim Buildings designer and see if it is working.Regards,Shreya
Answer Verified By: Fa Furrukh
Thats Owsem <3 its Working .. ThankyOu
Set the Reset Pop Up Menu to Press and Hold
