Hello all:
I'm trying to automatize the process of assing Instance Data to Meshes in Openbuilding.
I've realized that the keyin "dg add data" opens the Add instance Data tool. But Does anyone know how to select the Catalog type and after the Caltalog Item inside through a key in?
With those commands the instance assign process could be automatized through a VBA Macro.
Thanks in advance
Francisco
Hello Francisco,
As of now there is no Key in to open up the specific catalog type-item. But It seems like could be done through macro VBA. I will try to search for any existing knowledge base. Once i get that, will share with you.
Thanks & Regards, Arindam
