Was the edit weld symbol command removed or renamed in OBD U9.1?
Hi Ruston,
You can get the edit weld command in OBD U9.1 by inserting "detailer modify weld" in the Key-in dialog box . Please refer to the screengrab below.
HTH!
Regards,Sayan Acharyya
Answer Verified By: R RUSTON
