I have a space model file with labels which when referenced into another model, the text size appears very large. I've applied a rescale in the auto dimension for Building Design dialog in the originating model but there's no impact.
Hi Master,
Can you please share those DGN files with us for our further investigation?
Also, it would be good if you can provide a short video of the workflow.
Regards,Sayan Acharyya
Hi Sayan
Thanks for the feedback. I'm unable to load the files as they are sensitive. Essentially, a 3D model contains the space information. When it's referenced into another 3D model, the labels appear large. What is the typical workflow of bringing the labels into a drawing sheet.
Thanks for your prompt response.
I will follow the same workflow at my end and will let you know about my findings. Meanwhile can you please let us know which version of OpenBuildings Designer you are using?
RegardsSayan Acharyya
10.04.00.69
First thing that comes to mind, can the annotation scale have any influence?
Second, if not possible to upload these exact models. Can you create a new model with some virtual information that has the same issues? If reproduceable it will certainly help for support to find a solution.
