Disable Prostructures prompt on open
Hi all,
We recently updated to OBD U8 on the project, but we have hundreds if not thousands of files from previous stages of the project that were developed with ABD/MS.
Is there a way to disable the Prostructures update prompt on open of a file?
It's causing issues with any batch process we want to run with old files, as there needs to be a user clicking cancel on the prompt every time the batch process opens a new file.
Enrique
  • Hello Enrique,
    The prompt is coming to notify you that there are legacy structural sections that needs to be converted to PS elements. If you don't want to use PS elements then to toggle the legacy mode, you need to add an configuration variable BB_STRUCTURAL_LEGACY_ENABLE = 1 in any of the prefered cfg file. Please refer to this wiki for more. I hope this helps you.
    Product(s): OpenBuildings Designer Version(s): CONNECT Edition Area: ProStructures Interoperability Subarea: Configuration Legacy Structural mode can be enabled…
    Alifur
    Answer Verified By: Enrique F
  • hm - that didn't help for me.
    I got the following message and still have the pop up/Thomas
    _USTN_WORKSPACENAME = CINARCworkspace
    _USTN_WORKSETNAME = CINARCworkset
    PS_MATERIALFILE = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Data\ProStructuresMaterial.mdb
        Evaluation finds no files
    PS_SHAPESDATABASES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Shapes\Custom_Metric.mdb
    PS_BOLTINGASSEMBLIES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\MechanicalFasteners\Bolts\
        No files with extension .bsy are found
    PS_BOLTINGASSEMBLIESLIST = C:\B\CEws\CINARCworkspace\Standards\ProStructures\MechanicalFasteners\Bolts\PsBoltList.bls
        File does not exist
    PS_CODESSELECTION = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Rebar\PcCodeSettings.xml
        File does not exist
    PS_POSITIONFLAGSTYLES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\PositionFlags\
        No files with extension .psy are found
    PS_DETAILSTYLES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Details\Styles\
        No files with extension .stx are found
    PS_DRAWINGFRAMEDEFINITION = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Details\
        No files with extension .frm are found
    PS_DRAWINGSCALETEMPLATE = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Details\
        No files with extension .scl are found
    PS_ELEVATIONFLAGSTYLES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\ElevationFlags\
        No files with extension .ksy are found
    PS_PARTLISTTEMPLATES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Partlist\
        No files with extension .lst are found
    PS_CONCRETEPARTLISTTEMPLATES = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Partlist\Concrete\
    Can not find the custom-defined configuration file at C:\B\CEws\CINARCworkspace.cfg     CORRECT - no such file
    To resolve this error add the below statement to the configuration file CINARCworkspace.cfg located at C:\B\CEws\CINARCworkspace.cfg
    %include $(_USTN_WORKSPACESTANDARDS) ProStructures/*.cfg
    Can not find the custom-defined configuration file at C:\B\CEws\CINARCworkspace\WorkSets\CINARCworkset.cfg
    To resolve this error add the below statement to the configuration file CINARCworkset.cfg located at C:\B\CEws\CINARCworkspace\WorkSets\CINARCworkset.cfg
    %include $(_USTN_WORKSETSTANDARDS) ProStructures/*.cfg
    REBAR = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Rebar\
        Directory does not exist
    REBAR_PROJECT = C:\B\CEws\CINARCworkspace\Standards\ProStructures\Rebar\Detailing\Metric\
    regards /Thomas Voghera
  • Hello Thomas,
    Interesting, The PS dialog and all these messages should go away once that variable is put in one of the CFG files. Can you please raise an SR so that we can have a live meeting and see why it is happening.
    Alifur
  • OK, I'll do that in a few days.
