OpenBuildings iModel Publication Error
Recently I encounter frequent error when publishing iModel for updated design file which results in package creation failure. As interim solution, I copy the updated design to previous file version (which has no iModel publication issue) via referencing method and manage to publish iModel.
What could be the root causes to this error? I did remove all reference files prior to publishing iModel exactly the same to what I did successfully publishing previous design file version
