To whom it may concern,
using version 08.11.09.866 up to now it was always possible to print a pdf (stored in the original drawing) and the drawing together.
Now I see the drawing and the pdf in the print preview, but only the drawing is printed. I have not changed the printer or anything in the printing conventions.
It also doesn't matter, whether the background of the pdf is transparent or not,or if I turn on halftone printing. The pdf itself is stored in the drawing and not in the background.
WHAT works is to place the pdf directly in the layout - then it will be displayed and printed, but that's not what I really need.
If anyone has an idea what i'm doing wrong, I would be happy :-)
Thank you and Best Regards
Carsten
Hi Carsten,
This is a Learning support forum, your question is related to a product. If you can share the product name I can move the query to the appropriate forum.
Thanks!
Sorry - my topic is related to a printing problem with AECOsim Building Designer V81, Version 08.11.09.866 Hope it helps Best Regards Carsten
