Hi Bentley Users,
Knowing that we can create custom equipment/ component in OpenPlant Modeler under Equipment - User Defined - Create Equipment, I am curious if we can create same in OBD. Our project defines to model electrical discipline on OBD. It is having difficulty to put tags & properties for electrical equipment like panels, MCC, transformers. Even though I can do it in OPM, my sub-contractor has only OBD. Thank you.
Thiha
Hello Kyaw,
In electrical, what are the custom elements that you were trying to add?
Kyaw Thiha said:It is having difficulty to put tags & properties for electrical equipment like panels, MCC, transformers.
Have you tried to use the modify elements dialog as well as Schedules to edit / modify the properties?
Also what is the version of OBD you are using?
Regards,Alifur
Hello Alifur,
Thanks for your advice. Actually I am new user for OBD CE. Could you please elaborate more for modify element dialog, schedule edit and modify properties? Or please direct me to previous forum discussion if there was any one? My OBD CE version is 10.9.0.83 (Update 6).
Refer to below snapshot, I modelled the generator under electrical family and I want to change its property from Triforma to ElectricalFixture "Generator" like above example "Transformer".
Hello Thina,
Please refer to the following tutorials for the purpose.
https://www.youtube.com/watch?v=AJhwjOl7ei8
