BFP Huge File Size
Hey, I'm having an issue with a BFP file size.  The file is clocking in at over 11MB. The building isn't huge, and bigger buildings are only about 1.5MB. I've compressed, I've cleaned up, I've manually deleted everything out of the file I can - no references or unused cells, layers, text or dimension styles.  I'm at a loss on how to cut this file down in size.
Could it be the fact that there's an extensive design history attached to the file? Can I delete the design history without affecting the database connections?
Any suggestions?
Jim
MicroStation CONNECT Edition Update 10 - V10.10.00.23
Bentley Facilities Space Planner Update 10 - V10.0.0.47
Parents Reply Children
