Just wondering if there's something that I miss when looking at chamfering/filleting/cutting PS structural elements in OBD 9.1.
In V8i, I can use the following commands to interact with structural elements:
keyin: construct cut (works with line strings/shapes)
keyin: chamfer edges (drop structural elements to solids)
keyin: fillet edges (drop structural elements to solids)
In CE 9.1, things are quite tedious:
keyin: construct cut (works as V8i, but now only available through legacy toolbox)
keyin: chamfer edges (no longer works on PS structural elements, replaced by polycut/cut openings tool which only take polygon points as input)
keyin: fillet edges (no longer works on PS structural elements, replaced by cut openings tool which only take curve/arc elements as input)
Is there any other easier way get a fillet/cut out/chamfer on PS elements?
Best regards,
Tuan Le
actually, I can't work how to apply a fillet to a PS element.
It seems the legacy "construct cut" tool is the only tool can be used to for making fillet cut on PS elements.
Hi Tuan, Thanks for raising this issue over the SR.
As mentioned we have a Defect filed for Cut solid by Curve, fillet edge, Chamfer edge, and other related tools that do not work on Prostructure elements and are linked with your SR.
Also, share the wiki link regarding this issue from our community.
HTH,
Shivam Soni
