I am new to open buildings designer, how can I change the Building template to a UK version?
Mark
First question - did you downloaded the UK dataset when you installed the software
If you did then the BuildingTemplate _UK will be visible in the list of WorkSets when you load the software and access a recently opens file. The default installation is the US dataset
If it is there click on it to active that as the WorkSet
If it is not listed then you will have to install it which basically mean
Go to install OBD but go to Modify and select the DataSets you want to install
Click on done and the additional datasets will install,
Reboot computer and the Building Template_UK should now be available, click on it and that will be the dataset you are using
Hope that helps
Ian
currently using OBD 10.10.01.151
Answer Verified By: Mark Burke
