axis not showing
my axis is not showing , beofre showing , after my file crash so axis is not showing
  • Hi Furrukh,
    Do you want to see the ECS Axis?
    Shreya
  • check please
  • Hi Furrukh,
    Can you please try to rename/remove your "Prefs" folder from this location: "C:\Users\Your_Name\AppData\Local\Bentley\AECOsimBuildingDesigner" and then restart your ABD? Please refer to the screengrab below for your reference.
    HTH!
    Sayan Acharyya
    Answer Verified By: Fa Furrukh
  • Hi Furrukh,
    Great! It's good to know that renaming/removing the Prefs folder resolved the issue at your end Slight smile
    Have a good day ahead!
    Sayan Acharyya
