I am trying to import a Revit Drawing in to Energy Simulator.
I read in some answers to this question and I trying to import a .xml file, but when i import I am seeing the following error message - REVIT MASTER.xml, could not be loaded. I also didn't see the option to import an .xml file in the drop down list of files to import.
How to import a Revit File in to Energy Sim
Sean
Hey Sean,
Thanks for raising this,
A revit file is very likely a BIM file contraing BIM related data to it, if you can export that in to an xml file, (should be possible through revit itself) this xml is acceptable at Energyb Sim's end. See below:
In addition, it would be great if you could share the example file so we can test the same at our end.
Krishnendu
