Is there anyway to set the "visible edges" field of the "Create Drawing" dialog to "dynamic" by default? I created a custom drawingseed with that setting set to dynamic but when used, the dialog still start with "cached" option.
Best regards,
Tuan Le
Hi Tuan,
Thanks for raising this issue.
You need define this variable MS_REF_VISEDGE_ATTACH_STATE value to Dynamic. Afterward while creating drawing you can able to see the Visible edge set to Dynamic by default. Please refer to the below screengrab and wiki for you reference.
Shivam Soni
Answer Verified By: Tuan Le
Thank Shivam,
You're welcomeRegards,
