I installed Open Building again, and went to the steps described in BIM Management 301 Installation and Upgrade Guide to configure a network location, company workspaces etc, but I cant get it to work. I get this message when I try to create a file and open it:
Configuration Audit Alert.
(My File) does not define an adequate configuration for Pro Structures.
What have I done wrong?
There are a detailed description in the outputfolder:
_USTN_WORKSPACENAME = PLANKEAS_WorkSpace_USTN_WORKSETNAME = 0TEST
PS_MATERIALFILE = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Data\ProStructuresMaterial.mdb Evaluation finds no files
PS_BOLTINGASSEMBLIES = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\MechanicalFasteners\Bolts\ No files with extension .bsy are found
PS_BOLTINGASSEMBLIESLIST = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\MechanicalFasteners\Bolts\PsBoltList.bls File does not exist
PS_CODESSELECTION = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Rebar\PcCodeSettings.xml File does not exist
PS_POSITIONFLAGSTYLES = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\PositionFlags\ No files with extension .psy are found
PS_DETAILSTYLES = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Details\Styles\ No files with extension .stx are found
PS_DRAWINGFRAMEDEFINITION = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Details\ No files with extension .frm are found
PS_DRAWINGSCALETEMPLATE = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Details\ No files with extension .scl are found
PS_ELEVATIONFLAGSTYLES = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\ElevationFlags\ No files with extension .ksy are found
PS_PARTLISTTEMPLATES = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Partlist\ No files with extension .lst are found
PS_CONCRETEPARTLISTTEMPLATES = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Partlist\Concrete\ No files with extension .lst are found
Can not find the custom-defined configuration file at C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace.cfg
To resolve this error add the below statement to the configuration file PLANKEAS_WorkSpace.cfg located at C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace.cfg
%include $(_USTN_WORKSPACESTANDARDS) ProStructures/*.cfg
Can not find the custom-defined configuration file at C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\WorkSets\0TEST.cfg
To resolve this error add the below statement to the configuration file 0TEST.cfg located at C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\WorkSets\0TEST.cfg
%include $(_USTN_WORKSETSTANDARDS) ProStructures/*.cfg
REBAR = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Rebar\ Directory does not exist
REBAR_PROJECT = C:\Users\EllenPC\OneDrive\_OpenBuildingCE-Configuration\WorkSpaces\PLANKEAS_WorkSpace\Standards\ProStructures\GreatBritain\Rebar\Detailing\Metric\ Directory does not exist
Hi Ellen,Here is the wiki that can help you to solve this issue,
Answer Verified By: Steve Cocchi
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: ProStructuresConfigAudit
Hi Ellen,Here is the wiki that can help you to solve this issue,You can also look into this link below,HTHRegards,Shreya Basu
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.Flag this post as spam/abuse.
