I'm having trouble creating a STF Quantity report (Structural Quantity Spreadsheet). It opens the spreadsheet ok. But when I begin the structural report, it tries to load something but produces nothing. I have noticed at the bottom of spreadsheet that the accessibility is set to unavailable? I'm pretty sure this will have something to do with it but I have followed the prompts to change the accessibility, It did something to the layout of the excel spreadsheet but didn't change the result. It still wont do report and the accessibility is still set to unavailable?
Please can someone tell me how to correct this problem
Hi James,
Thanks for letting us know about the version of OBD you are using.
Can you please try to rename/remove your "Prefs" folder from this location: "C:\Users\User_Name\AppData\Local\Bentley\OpenBuildingsDesigner" and then restart your OBD? Please refer to the below screengrab for your reference.
Please do let us know about the outcome.
Regards,Sayan Acharyya
Can you please let us know which version of OpenBuildings Designer you are using?
Meanwhile we have a wiki from our community. Please have a look at this wiki.
