OpenBuildings CE Updated 9 Version 10.09.01.38
Previously in AECOsim when creating a dynamic view and placing the drawing model in a sheet, you were able to control the level display from nested references in the sheet independently from the default model space. Now, in OpenBuildings CE Update 9 when you turn the level display on/off in the sheet model from a nested reference and then jump back to the default model and turn on the level display on/off in reference files they appear again when you go back into the sheet model.
Dan Ruston
Hello Dan,
If i understand correctly then you are turning an level off in the sheet model to get a proper look in the sheet model. After that you are going back to the drawing model and there you are turning that level on again?
Also it would be helpful if you can share a video of the workflow to understand the query.
Regards,Alifur
yes and no, before we were able to control each space (design, drawing & sheet) independently of each other. Now lets say in the design model I create a dynamic view with all references turned off and create a sheet, once I go back in the design model and turn a reference on and level display it also displays in the sheet model as well. In AECOsim we were able to toggle nested references levels on and off in the sheet model without the design model affecting it.
