Hello, when modifying a door with PCS , the door appears at point 0,0,0 with the modification, instead of changing the door that I modified.
How can i fix this?
Watch video
Saludos
antonio
Xeon E5520, Ram 16Gb, Windows 10 versión 21H2, Nvidia K4000 OBD CE 10.08.00.44
I've re-attached the video, sorry
Hello Antonio,
I can see the same issue on my end too. Possibly it looks like a bug. The door PAZ files reside inside C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_XX\Frame\Doors. So try to modify them first and then place them in the design model.
Regards,Alifur
Hello Alifur,
I created a new PAZ file and the problem is the same.
After the file is placed in the model, if it is modified, another modified copy appears at point 0,0,0.
It does not appear to be a problem with the PAZ file delivered with the program.
Yes once you place the element then if you modify then the issue is occurring that is why i was mentioning to edit the PAZ before placing it.
What you indicate is a solution.
In the V8i version this worked correctly.
I see that in Connect Edition this has changed.
Regards.
Antonio
