Hello, when modifying a door with PCS , the door appears at point 0,0,0 with the modification, instead of changing the door that I modified.
How can i fix this?
Watch video
Saludos
antonio
Xeon E5520, Ram 16Gb, Windows 10 versión 21H2, Nvidia K4000 OBD CE 10.08.00.44
Hello Alifur,
What you indicate is a solution.
In the V8i version this worked correctly.
I see that in Connect Edition this has changed.
Regards.
Antonio
