Placing a spiral stair I want to set the stairs measurments like number of steps per 360° riser, riser height etc like in Stair tool in ABD.
I don't see it in Modify Stair-dialog?
Hello Thomas,
The modify stair dialog is present on the placement dialog. Please look at the below image to get the better picture.
I hope this helps you.
Alifur
Answer Verified By: Steve Cocchi
OK, I see it is the same place in Modify Stair. Thanks for quick answer.
Any reason the geometry settings isn't in the first dialog?
If you do tentattive settings to find best solution this is not optimal/many clicks!
regards /Thomas Voghera
yes it can also be found on the Modify dialog, I would guess to reduce the complexity on the UI it has been done from there, Also once a setting is done, then it can be used multiple time.
Regards,Alifur
