Structural settings menu not opening
When I try to open the structural settings menu, it fails to do so. It doesn't matter if I try to do so from the search prompt, or from file>settings>building>structural settings. It does not crash, it does not give an error, or any kind of message, in the message center, it just does nothing.
I need access to these settings to turn off the irritating markers in railings, which popped up again after a crash. Unless somebody knows of another way to turn these off?
I am using Openbuildingsdesigner version 10.09.02.36
It hasn't been always like this, although I couldn't tell you when it started. It doesn't seem to happen with my colleagues, who should be using the (more or less) same settings. It als happens in all files. It doesn't seem to affect other setting windows.
With kind regards,
Jeroen
