I don't suppose someone has a complete set of ProStructures JIS section libraries they are willing to share??
Hi Bear,
Thanks for raising this.
We will have some internal discussion regarding this and will update you accordingly.
Regards,Sayan Acharyya
Sayan, I'm not trying to raise anything, just trying to avoid a lot of extra work if I can find a generous soul out there.
Are you saying there is work being done on correcting these libraries as we speak?
Hello Bear,
I can see the JIS sections are present inside OBD in Japan.mdb. Can you please tell us exactly what is wrong in that database so that we can report that to the development team for rectification.
Regards,Alifur
The JIS library from ProStructures is not correct. I already have an enhancement logged for this. Just seeing if someone has been through the process that would be willing to share.
No luck so rebuilding the library myself.
Thank you for the response. But i am not seeing any enhancement logged for the JIS section in the system. Can you please share the number with us please.
