Complete JIS Section Library
I don't suppose someone has a complete set of ProStructures JIS section libraries they are willing to share??
  • See below:
    'To ensure your response gets to us, please do not delete or modify the subject line when replying: {SrvReqNo:[7001441898]}
    Hello Sean Forward,
    This email refers to Service Request 7001441898, submitted on behalf of Aerison Services Pty Ltd.
    Description: JIS_CHNL Sections Not JIS Delivered Size
    Product: OpenBuildings Designer
    Product Area: Modeling
    I would like to inform you that this issue resulted in Enhancement Request 960146. We are continuously improving our products via regular CONNECT Edition updates, during which we implement many of the Enhancement Requests reported by our users.
    Meanwhile the status of this SR will be Open-Enhancement filed. Once this enhancement gets reflected within application, you will be notified.
    Shreya Basu
    Global Technical Support
    Original Text
    bear@roaminangler.com.au
    To:
    'Shreya Basu' <Shreya.Basu@bentley.com>;'Support Shared Mailbox' <support@bentley.com>
    CC:
    'Forward, Sean [C]' <Sean.Forward@aecom.com>
    Sent:
    01.08.22 10:12:45
    Subject:
    RE: {SrvReqNo:[7001441898]} JIS_CHNL Sections Not JIS Delivered Size
    WARNING: This email originated from outside of the organization. DO NOT click links, open attachments, or respond unless you recognize the sender and know the content is safe.
    Shreya,
    The issue I have is that the JIS sections delivered with ProStructures (PS), and thus OBD, are not correct according to my research.
    PFC channels delivered with PS are actually EU sections, and while these are used in the region, they are not strictly JIS sections.
    On the other hand, TFC sections ARE covered by JIS steel standards, these I found under JIS_CHNL_2, but there is also JIS_CHNL_3 that I can’t find in any JIS steel std.
    Also, there are only 2 Z purlin sections supplied under JIS_ZED, but there are quite a number of other section sizes that are not delivered.
    Part of what I need to do is sort out what we need to add as we have some major projects in this region coming up and I’m not used to this sort of confusion with Bentley delivered sections.
    I’m afraid I’m not available this week via Teams meeting, but will be free next week or happy to answer any further emails.
    Many thanks,
    Sean ‘Bear’ Forward
    Engineering Systems Consultant
    "Tell me, I'll forget.
    Show me, and I may remember.
    Involve me, and I'll understand." '
  • Hi Sean,
    I am taking care of that particular PBI and I have updated all the necessary details there. I will look into it and if anything else is needed from you will let you know. I will give you an update about it accordingly.
    Shreya
