We have a file where all references seem to be placed according to a scale (1:2), but we can't find where this setting is:-Reference scale is 1:1-Model Annotation scale is 1:1-When we measure lengths are 1/2 the length from the original files.-When we dimension them with linear dimensions they give the correct distance.-Working units are the sameIs there another place where you can change scales?
With kind regards and thanks in advance,
Jeroen
Hello Jeroen,
So the element's length is correct in the original file but when you are referencing the file in another file the elements length is getting half? This is very interesting. I tried to create a wall of length 3000mm and then referenced it with 1:1, i can see the length to be same.
Regards,Alifur
For those with a similar problem, my error was that an acs scale was set in the file.
Answer Verified By: jeroen.decooman
